RE: TWISTER SKYLIFT. ANYONE GOT ONE YET?
Hi, if you are finding that you have to give full forward and side motion on your Tx and the Heli barely moves.
On each rotor head look at the cyclic connecting rods and follow them down to a right angled pivot point you can move the rod outwards on that arm, try moving it out one hole first and see if you notice a difference, if not try one more.
You need to do this on the two front and the two rear rods to keep it all equally adjusted.
If you overdo the adjustment I think it would cause blade clash and could easily stall the blades as you become more confident in throwing it around, so I would only move it one hole at a time.
I hope this is helpful[sm=spinnyeyes.gif]
