Twin Electric Motors BIG PROBLEM
I need some help,
I have a twin Lightning, to which I have installed 2 brushless outrunner motors with 2 identical speed controllers (correct amps)
Because these motors are buried in the aircraft they were set up and tested as I went with the Hi Tec servo programmer, on manual function to run the engines and check everything. With everthing working correctly the fuselage and wings were sealed up.
I now came to fit the receiver and again individulally checked the motors with the TX.
The problem: one engine works and responds correctly the other dosn't. Checked again with the servo programmer and both function correctly.
Anyone have a clue whats going on, I cant find a problem.
Cheers
