RE: Engine maintenace
If you are going to store your engine make sure you clean the engine inside and out and do that in the same air temp that it is going to be stored in. If you maintain a steady temperature in and around the engine after it is free of fuel, moisture should not condense inside the engine, since it happens with a temp. change.
