RCU Forums - View Single Post - Installing a Clutch
Old 01-13-2008 | 01:10 AM
techrtr
Default Installing a Clutch
When installing the clutch and clutch bell on an engine, the manual recommends taking the back off of the engine and using one of those plastic crankshaft clamps to hold everything while you tighten the mounting nut. Problem is, you can't just pick up one of those clamps anywhere. Is there another way of keeping the crankshaft from turning while you tighten the clutch bell down?
