RE: axe cp thread
dkme:
Im not around any electrical or conductive type materials.
Everything funtioned properly except for the servo glitch @ throttle up. Other than that all was ok.
I do believe the the servo glitch caused the tail rotor malfunction. The glitch had to throw spikes through the gyro or reciever.
I operated outside and inside to try to get rid of servo glitch and tail spin with no success.
Teenage Pilot 13:
Brand new Li-po 950mAh 15c, 2x Li-Po 1500mAh 15c
Not flying around any metal or powerlines.
Dont have any mechanical problems. Electrical problems are the factor.
Antenna, solder to tail motor, controller antenna, loose plugs are all good.
Should probably have motor checked. Thanks ill let you know.
P.S. I probably should have told you that ive been into RC's for 23yrs now... Ive done battery and nitro in cars and planes. Never played with heli's or gyro equipment until now. Thought it might have been a comon problem fix.
