RCU Forums - View Single Post - Installing a Clutch
Old 01-13-2008 | 09:25 AM
evan-RCU's Avatar
evan-RCU
Default RE: Installing a Clutch
On smaller motors you can hold the fan or something enough to tighten it. If you really want to crank on it take the back plate off and put a piece of 1/2' square pine or hard wood in the back where the crank pin/ con rod comes up to the bottom of the cylinder to stop it from rotating. Be carefull not to turn it so hard to bend anything, you can.
