RCU Forums - View Single Post - TNPC Shoestring Build Thread
Old 01-13-2008 | 09:52 AM
  #31
reincarnate
Default RE: TNPC Shoestring Build Thread
Yeah Mike still here. Didn't get time to get to the shop until last night. High school wrestling season is coming to a close and am busy with that, and now daughters show choir season is going to go full tilt. With work thrown in, my time is limited to say the least!
I agree that the parts directory isn't a great deal of help, but it's better than nothing. John made an effort at least, which is more than I can say for a lot of mfg's.
Question on the wing leading edge. What did you use? Directions say 1/4" leading edge, and nothing else. The only 1/4" I found was two pieces of tri-stock, and they will not shape correctly. I have enough stock lying around that it isn't a problem, but I'm curious what you decided.
Also, what method did you use to locate the servo bay cover and get it cut into the sheeting so that everything lined up?
Should be ready to join wings and move on by mid week if I can get some time. I'll look into the vert and horizontal stab while glue dries this morning.
John, if you're listening, it's a great kit and a challenging and enjoyable build. But do future builders a favor...Upgrade the directions a little. I'm sure either Mike or myself could give some suggestions.
