ORIGINAL: theradioflyer
You might have it on the lat balance. Another thing is putting wash-out in the wing tips, this might help equalize the wing. If all else fails, put some heat on the left wing and twist the leading edge down a bit and off-set the roll.
Another thing I thought of... if you put it into a climb over 45 degrees does it want to yaw right? If it does trim the rudder.
Just trying to brain storm with ya
It's just one of those things (LOL). It flies fine but no mechanical zero on the ailerons. I'll mess with it when it's better outside. Wind isn't bad...but it's snowing pretty decient and I'm not going out in it unless I have to.
