RE: twist engine mounting?
The Twist 40 ARF manual calls for using 3mm socket head screws to mount the engine to the mount. The stated length is 20mm or 0.787 inch (just over 3/4"). Then they call for 3 mm washers & nuts. If this is what you have and it isn't working (for whatever reason) then you need longer screws which should be readliy available at the LHS. 8-32 hardware would do just as well if you have it laying around.
