RCU Forums - View Single Post - EVO 26GT2 , Changed ignition - Reduced performance
Old 01-13-2008 | 06:03 PM
pe reivers
Default RE: EVO 26GT2 , Changed ignition - Reduced performance
ORIGINAL: Ravivos
Hi Pe, thank you for your replay.
the new ignition looks exactly like the one int the following link:
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVO30943312[/link]
i really think i will have a hard time replacing this module, how can i explain the supplier that the ignition doesnt work right?
My eyesight is too bad for such a midget picture with no visible clue of the real item.
If you have a single magnet engine. are you sure it's a bluehead evolution? If I am well informed, the evolution MVVS's all have the twin magnet ignition. Check the engine numbers on the left and right mounting flanges, like D-58 (l-r), and communicate that with horizon, or order a twin magnet prop hub to go with the ignition you have now. The key location has never changed, so it should be the right thing to do when upgrading.
If then it still does not work OK, they sent you a faulty ignition.
