RE: warning-micro hydro
So which is it, 648, 603, or 609? Where do I get some? I think it might be easier to get it centered in the prop shaft with this method. Also you wouldn't have heat up the metal and compromise it's agility. Do you still sweat some solder on the cable ends to prevent freying and stiffen up the end that gets tightened in the coupler?
