RE: Advice fixing up my first plane...
As for the spinner, you can get any brand and any color that you want. The plastic ones are a lot less money than the metal ones. Just measure the old back plate to see what size to get. As for props, you might want to stick with the 10X6. You can use the wooden one that you have if it does not have any chips, cracks or signs of damage. If you need another one, you can get a Master Airscrew or APC, which do make them in a plastic type material. As for glues, a medium CA and epoxy should do the trick. Good Luck, Dave
