RE: Wren 54 mk3-PLEASE HELP!
Twist your glow plug leads around each other.... (that is one of the causes of funny RPM readings...confuses the ECU and it shuts down..)
Make sure your pump is primed and there is fuel in the line all the way to the engine
And as mentioned above, make sure you do not have your gas and fuel lines mixed up.
The 54 is a wonderful engine! you won't be sorry.......
