RE: Help with the bobcat bounce....
You can also turn the flaps off once your wheels have touch the ground. This relates back to the plane still "flying" at landing time. Turning off the flaps reduces the lift and makes the plane stick to the ground like glue.
The only problem is, if you need a go around....you might need that extra lift.
