ORIGINAL: cutaway
The problem with older kits is the wood usually sucked real bad and the die-crunching is atrocious. A set of plans and careful wood selection will usually produce a much better result.
This is so true in most cases but not always.
There are a few exceptions to the rule like this pic of an old P-38 kit. 323020286579
Please keep in mind I do mean that it is exceptional. The formers and ribs are not die cut. Plans are not typically blueprints either. Let us not forget those beatiful spinners and formed nose ! Really nice!
Keefer, that is a good search parameter. Lots of people do not use such inclusive/exclusive search parameters and come up with a lot of unwanted results to have to filter thruough.
Robert
