RCU Forums - View Single Post - Copter X 200 Thread
Old 01-15-2008 | 04:46 AM
soneebee's Avatar
soneebee
Default RE: Copter X 200 Thread
I have tried setting up the heli.. but I think I have to look for really small electrics to get the heli well balanced...
Main gear : 120T
Blade length : 225mm
Main shaft diam : 3mm
tail shaft diam: 2mm
Flybar: 1.5mm
tail boom OD : 10mm
The kit does not come with electrics. You can get the 2400Kv motor.. with the Elf 30A ESC.
lipo battery is only 85g
I tried to hover this little heli.. I think I have to shift the electrics position.. I am a little tail heavy... i Guess the gyro and ESC is really heavy... but I think This heli will be stable once all the parts are set correctly.
I was using the 4200KV motor.. but set the throttle power to only 35% - 50% max.. at hovering its only 30%.. but the head speed is good enough for the heli.. increasing the power is really scary... I think the 2400Kv motor will do fine.. since its running already at 3S unlike the Gaui using 2S lipo packs
[link]http://www.youtube.com/watch?v=Osdjf6e5H3E[/link]
[link]http://www.youtube.com/watch?v=HtUhhP9PW5k[/link]
Have shifted the parts around.. lipo is placed at the bottom plate. ESC on the top mount.. kinda made the CofG better.. heli seems to fly better too.. best test will be outdoors.. as for indoors heli is stable
[link]http://www.youtube.com/watch?v=6rYzC089fOQ[/link]
