ORIGINAL: Dr1Driver
(If you count them all, I have had AT LEAST 18 CA hinges fail in-flight.
Then you're not installing them correctly.
Dr.1
Ditto.
ORIGINAL: flyX
By the time you set the CA bottle down...it's too late to adjust it.lol
Then you too are not installing them properly. They should be adjusted BEFORE the glue is applied.
I am amazed at how many people do not install CA hinges properly, and then discredit the hinges.
See the link Charlie posted above. Installing them is easier than any other hinge method I have ever used - and I have used them all
