RCU Forums - View Single Post - Airfoilz RCU Extra 260
Old 01-15-2008 | 02:13 PM
bighead93
Default RE: Airfoilz RCU Extra 260
Ok...now we are going to CA the Ply Crutch! Work from the front of the Fuse back. Make sure you are getting enough CA in all of the cracks...focus on getting the CA in where the seperate pieces of Ply come together. Next...after you have CA'd all of the foam fuse doublers in place (Careful that you make a left and right side) test fit the foam skin to the ply crutch. Sand if needed...both sides need to fit the same! At this point remove the tabs on the top of the foam doublers. Now the tricky part!! Start with one side and begin gluing the skin to the crutch...start from the front and work back. Careful that everything is correct before gluing! After you have completed both sides...we will be moving on to the top of the fuse.
ID:	852014   Click image for larger version
ID:	852015   Click image for larger version
ID:	852016   Click image for larger version
ID:	852017   Click image for larger version
ID:	852018   Click image for larger version
ID:	852019   Click image for larger version
ID:	852020   Click image for larger version
ID:	852022   Click image for larger version
ID:	852023   Click image for larger version
ID:	852024   Click image for larger version
