RE: Airfoilz RCU Extra 260
Now we are going to work on completing the upper skin of the fuse. Use painters tape for the best results. Carefully squeeze the fuse together and using Med CA glue the skin to the fuse. Again...make sure that everything is lined up prior to gluing! Contiune from the tail forward...being careful that everything is straight. When you get to the nose area...use a ball point pen and makes some lines in the foam where it will be bent. Carefully place over the nose and CA. Now is the best time to apply the Fuse Graphics...like so!
