RE: Slo-V Problem - Not enough power to get off the ground
I agree with Raleigh on the balsa wood filler piece. Epoxy would add a lot of weight. I don't use anything in mine personally. The endcap should basically just be pushed in, you can probably get it out by working it gently back and forth.
