Needle Valve settings...
Just this last summer, I cleaned up an old gummy engine and got it running... kinda. I could get the engine started but it would die soon after. I assume (so I hope I don't make an ***** outta me) that it's a good chance that its the gas as it is many years old or the tank needs cleaned out because it has set for far too long with no use. I will fix these things before I try again, but I think I got lucky starting it cause I have absolutely no idea where to have the needle valve set. Are there any tricks on where to start out or any advice on how to adjust it? This info will be put away until the weather is nicer for me to try again, but will definitely be used.
I just wanted to say thank you to you guys for helping me out in my last post. I didn't think I would get that much help so quickly. I appreciate it!
