RCU Forums - View Single Post - Questions on CA Hinges
Old 01-15-2008 | 03:44 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Questions on CA Hinges
Actually, the wax pencil/crayon trick really doesn't do anything.
If anything It's NOT a good idea.
Look at it this way. A CA hinge is a plastic ribbon with a fibrous coating on both sides. When you add CA, it wicks its way into the fibers.
When you draw a wax line on it, that line sits on top of the fibers - so the CA will still wick under it, but now you have created a barrier on top where CA can "pool" because it can't wick into the fibers like it's supposed to.
