RCU Forums - View Single Post - Needle Valve settings...
Old 01-15-2008 | 04:41 PM
Norm Nestie
Default RE: Needle Valve settings...
If you are serious about getting it to run things must be in good order. Fresh gas, good fuel lines, good glow pug. If this is a 4 stroke you want to check that the valves atre both working freely. Turn needle valve all the way in and then back out about e turns. That should be a good place to start.
