RCU Forums - View Single Post - Will not start - idle?
Old 01-15-2008 | 08:24 PM
ehroof
Default RE: Will not start - idle?
the idle should be set so the carb is open 1mm, take the air filter off and check. if not turn the idle screw clocwise until its open a little. are you sure the glow plug is still good, they are known to go during break in and rich running. if the plug is not lighting up, the engine wont start.
