RE: Will not start - idle?
Glow plug is lighting - but with the glow igniter I received, it will not light but for like a minute - but with loner (which is gone now), it lit up perfectly and kept lit (glow plug igniter had a charge). With the idle screw I get a 1 mm opening almost, but the idle screw either in or out (counterclockwise or clockwise) does not seem to do a thing. Also, the mesh now I see is very loose. I hold the clutch gears (black) and then move the silver gear, and I can tun it freely (if I am doing this correct). I have no idea what the heck is going on here.
