RCU Forums - View Single Post - Will not start - idle?
Old 01-15-2008 | 10:41 PM
codokas
Default RE: Will not start - idle?
ORIGINAL: S.R.G.
Also, the mesh now I see is very loose. I hold the clutch gears (black) and then move the silver gear, and I can tun it freely (if I am doing this correct). I have no idea what the heck is going on here.
Make sure you are not turning the flywheel-and IMO that is what you are doing--this will turn freely
Correct on the black gear but then you rock the END of the bell--the smaller gear at the end of the bell-you have to reach in there a little to move that one
DOUG
