ORIGINAL: S.R.G.
Wow, then move this one to that end where you will then move the little one between that and that - LOL. Ok, talking in complete newbie form - do what? (lol)
LOL--OK you did good in holding the black gear
Now look at the end of the engine--there will be a big gear closer to the engine--that is the flywheel
Look further to the end of the clutch bell-the silver thing--you will see smaller gear ( or 2 if it's a 2 speed) this is the gear/s you have to get your finger on to check the mesh--any clearer LOL
DOUG
ORIGINAL: codokas
ORIGINAL: S.R.G.
Also, the mesh now I see is very loose. I hold the clutch gears (black) and then move the silver gear, and I can tun it freely (if I am doing this correct). I have no idea what the heck is going on here.
Make sure you are not turning the flywheel-and IMO that is what you are doing--this will turn freely
Correct on the black gear but then you rock the END of the bell--the smaller gear at the end of the bell-you have to reach in there a little to move that one
DOUG
