RCU Forums - View Single Post - Will not start - idle?
Old 01-16-2008 | 07:24 AM
Chubbysdad
Default RE: Will not start - idle?
no as I told you on the phone, hold the 2 black gears from the bottom and check the mesh by moving the clutchbell which you can not see from the bottom. It is the gear that comes in contact with those black gears . The flywheel on bottom does not come in contact with the spur gears.
