ORIGINAL: freeonthree
I made a little degree wheel tonight and checked my timing. It was too far advanced bigtime ! I had to elongate the slots in the sensor to make it go retard far enough to get to 30 degree's before TDC. Now, the screw on the left is right next to the sensor housing. Here's a pic showing my sensor position after setting the timing.
What did you use for s piston stop to ensure the degree wheel was zeroed properly?
