Old engines
Think I would look in exhaust port & see what color the piston is , if brown or black I would tear it down & clean piston & sleeve with steel wool or Scotch -brite. Wash it out good with alcohol & put it back together & run it . Make sure the head is tight, that will sometimes give the troubles you have. MAX H
