What starter are you using?
The standard 12 volt starters will work on most Ryobi's but what are you guys using on your larger engines. I have one Ryobi that can't be started with the standard starters and would like to move up to something with a little more power. Will the heavy duty starters sold by the suppliers work. Tower claims that their HD starter will work up to 1.8 cu. inch. How are starting the 46cc engines. I am presently using a 110 volt drill at home. Thanks
Cvan
