RCU Forums - View Single Post - Thoughts on Wind Tunnel
Old 04-14-2003 | 03:35 PM
Ben Lanterman's Avatar
Ben Lanterman
Default Thoughts on Wind Tunnel
It probably also indicates that for unflapped, unslatted, fixed configuration airfoils at low subsonic flight conditions that there is just one good shape. The designer of the Clark Y had some good intutitive vibes going on. I am impressed with both airfoils and the work that went into them.
The trips we used in the McDonnell Douglas (now Boeing) wind tunnels (a Polysonic 4X4 ft and Low Speed, a 12 ft cross section) were made from a strip of fine grit like sparse sandpaper at the 5% aft of the leading edge location.
We would mask off a 1/8 inch wide stripe, spray on some clear Krylon and sprinkle the grit onto the wet paint. It was felt that this was more subtle/finesse way of triping the boundary layer. The grit drag was in the noise of our ability to measure the force.
I often wonder why the same thing is not used by modelers some times? Especially in the glider duration type of contest.
