RCU Forums - View Single Post - Thoughts on Wind Tunnel
Old 04-14-2003 | 06:56 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default Trips
I did a test once using automotive striping tape on a 100" sailplane with a E-205 airfoil.
I first put a strip on the right wing at 25% then launched. The sailplane went straight up on tow, but after coming off tow it slightly turned left.
Next I put one strip at 10% on the left wing. On tow the plane pull slightly to the right, then it turned slightly to the left after coming off tow.
I then put a strip at 10% on the right wing. It launched straight, then turn slightly left after coming off tow.
I then add a stripe at 25% on the left wing. The plane launched straight and flew straight.
I concluded that the 10% strip was working at High CL, and the 25% was working at lower CLs.
