ORIGINAL: twn
PS does any one know the specific part number for the recommended large dubro hinges and do I just do the tail section and use the stock ca hinges on the ailerons or do I put the pinned hinges in the ailerons too?
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD940&P=7]Dubro Pinned hinges[/link]
The stock CA hinges are fine if you install them properly. This means removing the covering around the slot and drilling a hole in the center and using the proper amount/type of CA. CA hinges make some people nervous, but I think any hinge can fail if not properly installed.
