Fixing an uneven wing and stab?
I've had to cut out a stab from a fuselage once or twice, I CA'd a #11 blade to a small square of 1/4" ply and then used this tool to cut the fuse wall 1/4" above the glue joint. Rest the ply flat on the stab surface with the blade cutting into the side of the fuse and push it along.
Peter
