RCU Forums - View Single Post - FLOATATION
Thread: FLOATATION
Old 01-17-2008 | 09:54 AM
Ron Olson's Avatar
Ron Olson
Default RE: FLOATATION
You got lucky! A lot of times the 2-part or spray-in foams will blow the deck off the hull. If you use it in a nitro or gas powered boat it will also soak up fuel and oil over time.
Depending on the size of the boat, you can use pool noodles or foam pipe insulation.
