ORIGINAL: frankfearn
Not really alot been happening. Fuselage and cowl has been panel lined and primed up. I would like to add rivets but i am unsure how to get a good scale look. I would be greatful for any advice in this area.
I use a small diameter brass tube, sharpened on the inside, and chucked up in a soldering gun to burn flush rivets. I do this in a silver base coat of paint as it is usually harder than the primer and holds the rivets better.
