RE: Heli-Max Axe Ez....Please Read everyone
also, you might check for a bent link between your flybar and top blade holders. If it is not bent then lengthen it 1/2 turn and see if that helps. If it makes it worse, then shorten it 1 turn. If it doesnt get any better, set it back like it was. my swash is not level, but the heli has flown great for 30+ flights and it came from the factory unlevel (tilted to the front). Unless I break it or find out otherwise, Im just going to leave it. I tried leveling it out and had the same problem you are having so I put it back.
