RCU Forums - View Single Post - WildHare 28% Edge540T V2 Build and Mod
Old 01-17-2008 | 04:20 PM
Snaer810's Avatar
Snaer810
Default RE: WildHare 28% Edge540T V2 Build and Mod
Hey Keith,
Hadn't seen a post here for awhile so I thought I would say HI and see how your doing on your WH Edge???????
I have been working on a few things, but ended up having to order a few parts before I can go to much further.
I decided to get all the engine electronics mounted, including the kill switch. (42% products) Made for a nice installation...even has an LED by the Ing. switch to let you know when the Ing. is still on.
I'm setting the throtle & rudder servo, RX and batt pack in locations so I can get an idea of the CG location and if I'm going to have to move things around. Also to see if I need to order some other batt. or servo ext.'s......
After that i'll be taking off the engine...etc and sealing the engine box with urathane and remount everything with clamps and blue locktite.
I'll probably start on the hinges Sat. and hopefully I have my Slimline fuel dot by then to get satrtde on the plumbing. Should go fairly quick.
A few questions: Can you tell me if it makes a difference in what direction the servos are mounted. I see them mounted in different ways. I would always think you would want the spindal and control arm closer to the control surface??
Are you using the rods supplied in the hardware kit or did you find you could use H9 Titaium rods? Just wondering.....I'm thinking I'll stick with teh WH rods that Tom supplied.....but those H9 turnbuckles are nice.....
Well let me know how your coming on your project??????
Mike
ID:	853581   Click image for larger version
ID:	853582   Click image for larger version
ID:	853583   Click image for larger version
