RCU Forums - View Single Post - Yet another Sig Something Extra Build
Old 01-18-2008 | 12:00 AM
  #57
iron eagel's Avatar
iron eagel
Default RE: Yet another Sig Something Extra Build
I am really not trying to be critical here, I just think that it would be far better to not glue up the servo tray, landing gear block, or the reinforcements for F1 prior to fitting the wings to the fuse and make sure it is square before every thing is set in stone by gluing them up.
And I wanted to get opinions of other builders are far as their thoughts on it, before I proceeded. Perhaps it is not as much of an issue as i think and I am just bing to fussy about the whole thing.
As far as the tail, I intend to build over the plan so that I will be able to keep in in proper alignment, and where I am making some changes to the structure such as adding longerons to the bottom of the Fuselage so I can round it out on the lower edges rather than leaving it square or only the edges rounded out. I wanted to get some input from others whom have built these before and their thoughts about the build.
