RE: DA 100 Issues
Hi Pe,
Thanks for the feed back.
So I guess its the same as I used to do with the Zenhoas??
A few questions please.
Do I have to solder a tube onto the carb plate over the small hole through the plate on the front? ( Dumb question I know I just want to be sure ) Also when I used to do this the hole used to be in the middle of the plate. On this Walbro carb which made it easy... On this walbro the hole is right between the raised area and the flat outer.. On a radius [:@]
Last thing.. Does it have to go to a matchbox size hole? I used to just attach a tube through the firewall so it could breath from inside the fuselage. If it has to be a box then how much of an inlet do I make for this box? Or none at all???
Sorry for the daft questions.. I have got lazy with the fit and forget DA's that I have had up till now.
Regards Al
