RE: DA 100 Issues
Building a reversed scoop on the bottom of the cowl to provide positive hot air extraction helps eliminate pressures indide the cowl. Sometimes just cutting a large hole in the bottom of the cowl allows air to hit the firewall and make extraction of hot air not happen and build more pressure.
Your engines cooling will be improved also.
