RE: HBK2 Problem!
First of all.......... the HBK2 collective/pitch function causes the swashplate to move upwards towards the main blades. this is with the stock Esky TX. Eflites collective/pitch function is opposite. When more throttle is applied with the Eflite throttle stick it pulls the swashplate downwards towards the frame of the heli. I assume there are dip switches located inside Eflites Tx somewhere to change the pitch function (not the servo reversing switch on the front) but seriously you are really making it harder than it has to be. You are correct in that the programming is in the TX's themselves and not in the RX. Even if all your servo functions are correct without knowing how to change the Tx programming in the Eflite TX you will never get the pitch/collective to work properly. Not to mention you lose the ability to fine tune your headspeed and pitch angle with the knobs on the Esky TX.
Now is the time to invest in a better radio............. or buy a replacement Esky one. There are a ton of guys on this thread that have upgraded radios, myself included. If you like , PM me and we can talk about getting you a replacement TX.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
