RCU Forums - View Single Post - Hinge Glue?
Thread: Hinge Glue?
Old 01-18-2008 | 12:01 PM
gary9648
Default RE: Hinge Glue?
Pacer hinge glue works well when gluing hinges into wood. Other than that I use 30 min epoxy with micro balloons. Make sure you wash the hinges with good old soap and water first to remove all parting agent or oil from your hands. Then I use a drop of oil in the hinge pin. Drop glue in hole, thinnly coat hinge and install. Clean away any excess with alcohol.
