RE: Throttle Problem
Flyingsolo try putting the throttle switch in the original position and reversing the elevator and aileron servos. That will be you only hope of making it work. Also I think if one of the servos is reversed due to the transmitter then you would have to switch them all. So it is possible they will all have to be reversed. Unplug the motor as not to get chopped up and get the swash moving the right direction and then check the throttle. Once you get it right the 4 in 1 will arm. If you get it to arm then you need to check the tailrotor also. Good Luck Gittle.
