RCU Forums - View Single Post - Throttle Problem
Old 01-18-2008 | 06:31 PM
tippy
Default RE: Throttle Problem
ORIGINAL: flyinsolo11
Hey guys here is a wierd one.
I switched Tx from the Esky one to the Eflite one I had because the Esky fried on me.
Ever since this the throttle is acting weird. When I increase the throttle, the swash goes down instead of up. To compensate for this, I naturally switched the throttle setting to reverse on the Tx. Now the ESC wont run the motor. When I turn it on, it goes BBB BBB BBB BBB instead of B B B.
I am hoping to get a Futaba 6EX soon, but untill then I want to get this thing back airborne. Any ideas?
Thanks for the help!
That's not a throttle problem ... that's a pitch problem.
You need to reverse the pitch FUNCTION. If it's non-CCPM ... then reversing the pitch channel will reverse the pitch function. If it is CCPM, you need to reverse the pitch Function only and NOT the pitch channel.
Keeping in mind ... you may need features in your TX that is doesn't have (reversible channel & AFR menu). Getting a better TX is a good idea but unless you can reverse you pitch channel and/or function in the existing TX, I'd abandon the idea of trying to fly just yet.
