RE: CCBEC as a 6v regulator?
Yes it is a voltage regulator. It can be used without the airplane being electric. Using it in the way you describe will work with no problems.
It will handle input voltages from 2s to 6s lithium packs and you will be able to set the output voltage from 4.8v to 9.0volts.
