RE: Throttle Problem
I thought that might be the case but, I didn't know if you could reverse all of them or not. After thinking about it you would need to reverse the - and + numbers too along with the servos switches. If you had the other servos it would be easier to just swap them out as bkind said bacause you would have to pull them off the mod them. The mod is easy but you need a small soldering iron and a steady hand along with a good magnifying lamp. What it boils down to is you can reverse every thing on the Eflite radio but the pitch functions. Hmmm I learned something today which is a good thing. It does make perfectly good sense too. [sm=thumbs_up.gif] Happy Flying Gittle
