ORIGINAL: jtnktz
ORIGINAL: rshooch
thay are pretty much the same the lx1 is an updated verson of your buggy. dif. shocks,engine,and c hub suspension but as far as chassis lay out thay are the same
So I have the low model? Bummer.
you ve got yourself a good deal there, dont despire its a old model as it can be upgrated, the only problem is the front knuckles which is quite weak but you can upgrade it to lx1 with a few parts and it should be a tough basher, i would give it a good clean out and check all bearings
