RE: Stiff Hinge point hinges, Help !
Just work the last two hinges loose and next time, use Gorilla Glue. Best thing in the world for hinge points. I have used it for quite some time and never had a problem with it. Holds the hinge in and will never come out. Also, not as messy as Epoxy. CA is not the best glue for hinge points, but it can work. Just use Gorilla Glue next time and wipe off the foam while it is still soft, then clean up with an exacto knife. Beats CA hinges any time. I always throw CA hinges in the trash where they belong and install hinge points in their place. Never had one come out yet. You can also use Yellow wood glue to put them in and clean it up with a paper towel and water before the glue sets. I have used hinge points since they came out and never had a problem with them unlike CA hinges.
Ed
